914Sixer
Feb 16 2013, 05:30 PM
Just wanted to let everybody know these are still available from Porsche. Drill your holes, position and weld.
toolguy
Feb 16 2013, 05:38 PM
IIRC -I always thought they weld on the inside under the gas tank. . the matching [less threaded lugs] bushing holder sandwiches the fender between them. . .
They really need to be welded securely, not spot welded. . . Using a 19 mm sway bar, I ripped the factory ones out and tore the fender sheet metal in one season of time trials on 2 different 914's and one 911. . .
914Sixer
Feb 16 2013, 05:50 PM
Can some one take a picture of showing the mounting of these from the factory?
sixnotfour
Feb 16 2013, 06:49 PM
Outside from the factory..
914werke
Mar 1 2013, 12:44 AM
You dont even need to remove the tank.
zonedoubt
Mar 1 2013, 12:48 AM
QUOTE(rdauenhauer @ Feb 28 2013, 10:44 PM)
Grinding, welding, gas tank...uhm yeah.
mr914
Mar 1 2013, 07:12 PM
How much did the dealer charge?
The local dealers want $210 for a pair of wheel bearings for a 4....
Niklas
Mar 2 2013, 04:57 AM
There is pricelist in porsche.de. Check under classic.
They o
They cost in germany 13.15 Euro
Niklas
ChrisFoley
Mar 2 2013, 05:55 AM
Welding the oem reinforcements on the outside is fine for a factory bar on a street car with relatively narrow tires.
For competition cars and modified street cars a heavier duty plate should be welded on the inside so the inner fender is sandwiched between the reinforcement and the support bracket.
The reinforcements I've been making for many years have the same tri-oval shape as oem but the nuts are more securely welded to a heavier gauge plate. They should be 100% perimeter welded or stress cracks will eventually propagate from the ends of the welds.
I've raced for years using a 1 1/4" anti-sway bar without any cracks occurring in the chassis, My bar has more than twice the stiffness of a 22mm solid bar.
I've seen the factory reinforcements torn out of cars with less anti-sway bar and less tire than my car.
914Sixer
Mar 2 2013, 08:14 AM
Cost from Porsche was $17 each. They are special order, save a ton of freight and let them come in on the container. I use Hennessey Porsche in Roswell, GA.
CMONNETT
Mar 2 2013, 09:05 AM
Why not use your local dealer, Porsche of San Antonio? They're just down IH-10 from you. You would save on freight.
mr914
Mar 2 2013, 01:27 PM
Interesting... Did a google search and came up with some funky results
6 pages of.
Buy xxx xxx xxx at 944-parts.com
Same type of listing and web page with the following web links
Used-944parts.com
914parts.com
Partsfor944.com
914used.com
914part.com
porsche-993-parts.com
911-wheel.com
porsche-912-parts.com
All pages are the same crappy design that says "search for part #xxx xxx xxx
Guess what? All links lead to automobile Atlanta
