When the pads are cold, its fine, but when they heat up, it sounds like metal on metal. Time for new pads? AFAIK, these are stock pads, nothing fancy...
nebreitling
Nov 14 2004, 11:39 PM
might be time for new rotors, too
anthony
Nov 14 2004, 11:47 PM
And you haven't inspected them at the first sound of metal to metal screech???
ChrisReale
Nov 15 2004, 12:52 AM
QUOTE(anthony @ Nov 14 2004, 09:47 PM)
Rotors Mic fine. Never had to replace brake pads before, so..... They also only do it when they are warm to hot.
McMark
Nov 15 2004, 12:55 AM
Just remove a wheel and peek in the back of the caliper. Kinda hard to see in there, but you should be able to tell if the pads are gone. Could be a sticking piston that wore one side faster than the other.
krk
Nov 15 2004, 01:11 AM
Chris,
It sounds similar to my last brake experience --- check now. In my case, the delay ended up in warped rotors, which was an unnecessary added expense.
kim.
anthony
Nov 15 2004, 01:49 AM
Rotors Mic fine.
That's not going to tell you anything. I had the same thing happen. I couldn't see that the pad was gone untill I actually took the wheels off and pulled the pads out of the caliper. I think it was the inboard rear pad on one side which had worn more than the others.
