Bump.
I still have not gotten my rears on and I figured out why.
The car came with one set of wheels. The kind with the raised flat spot on the flower petals (dont see them in the PET).
The ones I am trying to put on the rear are different (still a stock 361-011-01) and the ~45mm bolts are too short. These bolts are 45mm including the head.
Is that the only stock length? When I checked all the FLAPS, that is the only length they had (too short).
So it seems that some of the stock bolts were longer than 45mm or I have some weird wheels or rear hub setup.
So it looks like I should get these:
http://www.race-studs.com/servlet/the-55/M...ace-Stud/DetailThey will give me 65mm of "stickout" from the rear hub
with the 60 degree nuts? (this is a race car) and then use loctite red to install them?
Stu
