[/quote]
You need to drain the transmission, remove the 2 bolts and pull the plate / fork out. Once out then you can use a hammer and punch tool to take out the pin. You will need to replace 2 seals in there. AA and pelican sells them. Easy job. Takes about 30 minutes once you drain the fluid.
Here is a picture of the fork out
