QUOTE(DBCooper @ Feb 19 2013, 03:21 PM)
No tin is an absolute no-no, so get that fixed before anything else, but don't expect it to ever be like an MG. The engine noise from water cooled cars is generally absorbed inside the heads and engine by the water jackets. They're also generally built to closer and quieter tolerances because they can be, since the water avoids the temperature extremes that A/C engines experience. A/C engines run hotter than water-cooled motors, so you don't see oil coolers on many water cooled cars, for example. And lastly those engines were designed back in the 1930's (1960's for the T4) so the technology is really old. Like in really OLD old, with solid lifters, lots of gap in the overhead valves, sheet metal valve covers that are pointed out toward the curb, best possible way to share all that racket with the whole world. Add deferred (!) maintenance and too loose valves and it's a lot. With water cooled cars you can use a stethoscope to check engine noises, with all the noise in aircooled VW motor you go crazy trying to figure out what's what. With a watercooled motor you can run a knock sensor. You can't in an aircooled VW motor because all the noises just plain baffle the poor thing.
bingo! thats the technical explanation i was looking for. now, my MG engine is water cooled, but it is also a pushrod engine with valves that must be adjusted...solid tappets and all. the sewing machine sound i'm used to, its the lack of water jacket to deaden the sounds of detonation that i'm not used to. of course, that whole phenomena is exacerbated in my case by the lack of tin! (yes, yes, yes, i've known since moment #1 that i MUST fix that before leaving the driveway. roger wilco.)
QUOTE(Jeff Bowlsby @ Feb 19 2013, 05:33 PM)
My stock 2.0L sounds like a sewing machine...whats the issue?
so does my MG. that means its running g-o-o-d. the MG engine (1.8 BMC B-series engine) has its origine in the pre-war Austin A-40 sports. the MG debuted in 1962 which means that its technology dates to the late '50s. with the OD tranny it cruises fine at 80 on the interstate. no tractors involved or necessary.
