SLKWrx
Feb 20 2013, 03:40 PM
I'm working on the replacement of the stock throttle cable with a Terry cable. The original bound up on removal pretty badly and the result was, I'm assuming, a piece of the old cable still left on the car. Does this look right? How does the Terry Cable attach? Do I just need to get rid of that brass looking piece and press on the Terry Cable? Any help is appreciated.
-- Steve
Jeffs9146
Feb 20 2013, 03:42 PM
You need to remove that yellow part before you put the new cable on, it was part of the original cable!
SLKWrx
Feb 20 2013, 03:49 PM
QUOTE(Jeffs9146 @ Feb 20 2013, 01:42 PM)
I figured as much. Is it just slid on? I attempted an easy removal and it feels pretty secure, wanted to check in before I moved to more drastic measures. Does the new cable get glued on or just placed?
Jeffs9146
Feb 20 2013, 03:51 PM
QUOTE(SLKWrx @ Feb 20 2013, 01:49 PM)
It is just slid on!
Use a pair of plyers to twist as you pull it off!
TheCabinetmaker
Feb 20 2013, 04:44 PM
Yep. Like Jeff said
Gint
Feb 21 2013, 10:01 PM
Just did that a while back. The collar from the old cable stayed on the tube. Pulled it right off and installed the new Terry cable. Done.
SLKWrx
Feb 23 2013, 06:38 PM
Ok, got the bottom piece on, however I'm still short... Am I doing something wrong here?
Mike Bellis
Feb 23 2013, 06:53 PM
QUOTE(SLKWrx @ Feb 23 2013, 04:38 PM)
Click to view attachmentLooks like you need to move up one bolt and to the other side of the case.
SLKWrx
Feb 23 2013, 06:56 PM
QUOTE(kg6dxn @ Feb 23 2013, 04:53 PM)
When I tried that, I got either an extreme angle or no room for the cable to actually retract. I'll try it again in the morning to see if I missed something.
-- Steve
Mike Bellis
Feb 23 2013, 07:02 PM
Spin the bracket around when you move it.
McMark
Feb 23 2013, 08:33 PM
When you put the clevis on the front of the cable (at the pedals), did you thread it on all the way? That point is an adjustment as well. You can see if you get enough slack by unthreading the clevis a bit. You could also run the bell crank the other way around, so the cable attaches on the 3&4 side.
Gint
Feb 24 2013, 01:19 PM
You want all the cable you can get. I never felt like I had enough cable for use with carbs though regardless, so I ordered a Terry cable and had them make it 4" longer in the sheath and the cable.
That bracket can mount in various locations along the spline of the case using the case bolts. You just have to flip it. And I bent my bracket a tad to get the proper angle.
SLKWrx
Feb 25 2013, 07:39 AM
Ok, thank you all for the help and support. Combination of problems/magic random fix. I rethreaded the cable about 10 times to ensure that it wasn't wound around the clutch cable, tried every different permutation of the bracket and finally the setup of the bracket on the other side of the block closer to the bellhousing worked.
Thanks again, couldn't have done it without this group!
