7TPorsh
Feb 21 2013, 03:50 PM
I have seen pictures of front suspensions being removed in one piece. I need to replace the front shock inserts, bushings, ties rods.
I don't have extensive tools so I am thinking it would be easier to drop the whole thing and replace the pieces one by one then install the whole thing back.
Easier to take to a machine shop to open joints, press bushings, etc.
Is this easy to do? What are the drop points?
oops, didn;t post in garage.
OU8AVW
Feb 21 2013, 06:47 PM
That's how i did it.
7TPorsh
Feb 21 2013, 09:55 PM
but where are the drop points? What order...totally new to me. Manuals don't show this technique.
VaccaRabite
Feb 21 2013, 10:02 PM
Not really a sequence.
Put a jack under the crossbar to hold everything in place.
unbolt the brake calipers the brake calipers, or undo the brake line to the caliper.
MARK THE POSITION OF THE SHOCK PLATE IN THE FRONT TRUNK WITH A SHARPIE (make a trace of the plate).
Unbolt the plate.
remove the pan that protects the steering rack.
unbolt the A arms at the front trunk.
Unbolt the bolts on the cross bar.
And the whole assembly should come down.
Eric_Shea
Feb 21 2013, 10:07 PM
Remove the suspension pan and place a jack on the crossmember. Remove the tank and the steering rack coupling to the steering rack (unless you want to remove the two fasteners on the steering rack and take the ball joints off yourself) Then remove the strut top nuts. Then the crossmember bolts. Then the front suspension bolts. Lower the jack.
Eric_Shea
Feb 21 2013, 10:08 PM
Unbolt the plate.
Why? Leave it in place and remove the strut.
7TPorsh
Feb 22 2013, 12:12 PM
does the rack drop too? or the suspension drops and rack stays in place.
7TPorsh
Feb 22 2013, 12:13 PM
There was a pic of this on a few threads...can't find it now.
Feb 22 2013, 12:54 PM
QUOTE(7TPorsh @ Feb 22 2013, 10:13 AM)
Like Eric mentioned, you can leave the top shock plates in place and just unbolt the strut.
That way, you keep your current alignment.
7TPorsh
Feb 22 2013, 12:57 PM
wow, comes with the wheels on! Looks like I need to pull the gas tank.........again
Chris Pincetich
Feb 22 2013, 02:29 PM
I took the tie rods off the steering rack and left the steering rack in, leaving the gas tank in place.
Replacing the ball joint is toughest. I had to use a hammer on another tool placed in the notched slots for removal and installation and it has been solid for 3+ year.
Ask around and maybe you can borrow a balljoint socket
OU8AVW
Mar 8 2013, 01:09 PM
A ball joint socket and an impact make quick work of the job.
Ductech
Mar 9 2013, 01:45 PM
That's it ... Next shop tool is a fork lift. I never thought I could lift a teener
jacksun
May 28 2014, 07:54 AM
thank you for this thread....
really helped with choosing a direction.
tks
r
green914
May 28 2014, 09:20 AM
Thanks for the good info
Dave_Darling
May 28 2014, 04:01 PM
QUOTE(ChrisNPDrider @ Feb 22 2013, 01:29 PM)
Careful with the commonly-available ball joint socket. It's not very strong...
I would suggest using an air chisel on the retaining nut. You want to replace the nut anyway, so it doesn't really matter if you chew the heck out of it.
--DD
jmill
May 28 2014, 06:00 PM
I had to grind down a wrench to remove and replace the tie rods. Not sure what's in your toolbox.
jmill
May 28 2014, 06:09 PM
QUOTE(Dave_Darling @ May 28 2014, 05:01 PM)
--DD
If you don't have a vice, it's way easier to break it loose when it's on the car. BTDT
