QUOTE(motorvated @ Feb 22 2013, 07:57 PM)
Thank you Randall, I'll do just that. Having a remote oil filter location doesn't sound too bad to me either!
This picture below taken from underneath my car shows the dual filter set up as well as the lines leading to the front cooler (and return). FYI I also run an Accusump which saves engines. That bottom 90 degree line is the one going back to the Accusump, if I remember right.
Click to view attachmentAlways thought it would be interesting to video an accusump during an autox, going around corners when oil pressure likely drops. Haven't done it yet.
And here is the connection to the engine/ oil pump. This engine has an external oil return to the pump as the builder didn't like the internal oil return configuration.
