I've read about plug welding the front bracket to avoid hacking a big hole in the tunnel. Does anyone have pictures, advice, lessons learned? From what I've read I need to drill a couple holes ~1/4" for the weld. Am I welding the bracket back to the tunnel? I assume we're not talking about welding the clutch tube directly to the tunnel as I would think there is a big risk of weld inside the tube that would restrict the cable. My neighbor is pretty good with a wire feed machine and has volunteered to help while I man the fire bottle.
Thanks for any advice you can provide...
Mike
