QUOTE(Cap'n Krusty @ Mar 5 2013, 02:56 PM)
Well, lets get this right. There's a CHT sensor, same place they always are, and an air temperature sensor inside the air box. NOT replaceable. Air leaks will NOT make the engine run rich. To the contrary, they'll make it run lean. Large air leaks will make it not run at all. And they don't have to be all that big, like a loose oil cap, or a bad oil cap o-ring (one, or both). Adjust the valves, check and/or replace the points, set the dwell and the timing (NOTE: the timing is set in a manner completely different than that of the D-jet engines!) Make sure the vacuum can works. Set the idle speed, set the idle mixture with the screw on the air box. If that doesn't fix it, check the fuel pressure at idle. Then make sure the cold start valve isn't leaking (VERY rare). Should be right about 30 PSI. If it still runs fat, you probably have a bad air box. Good luck with finding one. I have a PDF of the factory troubleshooting guide, available free to anyone with sufficient inbox capacity to get it in an e-mail.
BTW, the sensor under the manifold is the thermotime switch, a part of the cold start system. Has nothing to do with anything once the car is started, and only works when the temps are under 30 degrees F.
The Cap'n
Thanks Cap'n. I haven't started it back up since I replaced the injector seals (inner and outer) and the intake manifold tube hoses, sealed up the intake "snorkle" tube (between Air Flow Sensor and Throttle Plate/Switch) and replaced the rubber elbow to the auxillary air valve which was cracked. I'm hooked up to the CHT on the 3/4 bank, and there are two spade connectors from the harness going to tabs on the 3/4 side of the manifold down low. (Sorry no pictures) Those two look more like grounds. I have only one plug that goes into the air cleaner housing and that's for the Air Flow Sensor. There doesn't seem to be any place on the housing that would indicate a missing component. Haven't looked at the points or checked timing yet, but will soon. I'm hoping that eliminating the air leaks and tuning will do the trick.
