I am in the same boat. Since you are there might as well check the clutch tube and check if it has separated from the tunnel weld. That is what lead me address the tunnel rust as well. I got the following from the Q/A for metal. So I am thinking it is not so suited for the tunnel since it needs to be washed off or is the white powder after it dries is ok ??
I mean geez once you spray the metal ready in the tunnel how the heck you going to dry it out. The eastwood product may be better suited. Thats just my thoughts.
"Must I wash off the Metal-Ready after using it?
Yes. Otherwise, a powdery residue will be left after the metal dries. This can be removed with a wet rag or by
hosing it off. After washing off the treated Metal-Ready surface, dry it with warm air (hair dryer) or with towels,
etc. Flash rust could appear if the surface isn't dried quickly, but your first coat of POR-15 will remove it and adhesion
will actually be enhanced because of the flash rust. Remember, POR-15 can be painted right over rust.
