Just corded another rear tire on outboard edge due to in adequate negative camber...Unable to get more than 1.8 - 1.9 ...All shims out..... How can it be done without chopping up the car. Looking for at least 2.5 Thanks Terry
Krieger
Mar 11 2013, 09:36 AM
I spoke to Chris at tangerine racing about this once. He sells his own trailing arm brackets that he might be able to build with a little more camber.
Woody
Mar 11 2013, 10:43 AM
How low is the car?
Mar 11 2013, 11:48 AM
Stupid idea, but maybe a custom shim that is cut at an angle? Thin on the outside and thick on the inside.
In theory, that should give you more negative camber ...
sixaddict
Mar 11 2013, 12:30 PM
Thanks Spoke to Chris this morning and first thing he said is LOWER the car....Or he should have said it in caps ...Been debating that with shop but he added some valuable info. May need to move spindles a bit to allow front to match but I am betting we are going down !
Thanks
Mar 11 2013, 03:54 PM
QUOTE(SirAndy @ Mar 11 2013, 10:48 AM)
Well, after giving this some more thought, the wedge would only work if you relocated (lowered) the mounting hole on the inner suspension ear.
Still, that might be a viable option ...
spaceshuttle
Mar 16 2013, 09:24 PM
QUOTE(sixaddict @ Mar 11 2013, 10:30 AM)
Thanks
Good thing you made your splitter/air dam removeable
naro914
Mar 19 2013, 06:07 AM
Yes, you need to lower it. And sell the 17" and go back to 16" wheels.
