QUOTE(Bleyseng @ Mar 12 2013, 05:54 AM)
QUOTE(wndsnd @ Mar 11 2013, 04:59 PM)
So if I want to use the stock FI, I am better having the heads machined to accept the new cylinders.
But if I decide to choke down the carbs so to speak, I would be better off with the 2.0 heads?
yes, as athe 2.0L heads give more hp with their bigger valves, ports and plug angle. If you use the 1.7 heads have them rebuilt with 42x36 valves along with the 96mm cylinders its gives you a nice engine. Set the CR to 8to1.
Not to speak for John, but his goal at this time is to stop some of the bleeding and get the car on the road.
He has a 1.7 he got from dANNy that is supposed to be low miles. I'll let him tell you why he has the heads off, but doesn't want to split the case.
I suggested that I would put the 96mm kit on it "just because" he is right there and if the engine turns out to not be good, he can use them on whatever engine he decides to use. Since he already has all the parts I also suggested he stay with the d-Jet.
So the idea here is not to build a long term engine or engage in more project creep, but to get the engine running well, the car on the road and decide where to go from there.
With that in mind, big valve heads and the like are out. Once you go that deep I think he should just keep looking for a good running 2.0 that is being replaced with a 6, but that doesn't get him on the road this spring!
