QUOTE(KELTY360 @ Mar 14 2013, 09:30 AM)
QUOTE(Kaduku @ Mar 13 2013, 09:28 PM)
Both the small B light and the main section above don't light up. Any thoughts on where to start looking for the problem
This must be a recent glitch Randy. That B light would come on when you first turn the ignition to 'on' and i know the E-brake light was working. What have you done recently in the area of the dash and fuse box?
Hi Marc, good to hear from you!
First to answer type47's question, the gauge I have don't have a temp sensor like the one you have pictured, it is blank. That B thing is right where the word TEMP is on your gauge.
Marc, the B light does not turn on when I first turn the ignition. When the car first arrived, the turn signal indicators did not work, so I spun the fuses like you did and then they worked.
I will re-spun the fuses and check for the hand brake. I guess in this case, the reset button may not apply right?
I'll report back later. Thanks everyone!
