QUOTE(jhadler @ Mar 14 2013, 01:52 PM)
Okay, so looking at the fleabay add and pictures, there would be one concern right away that I would have...
Cooling. The radiator is mounted flat on the floor and it would appear that it's drawing in air from under the car and venting out through the wheel wells. Seems awfully inefficient to me, and I would wonder if it wouldn't overheat on hot days. Very poor air inlet. Low pressure, and hotter incoming air. Fans can only move so much air.
-Josh
Cooling
might will be a problem in Las Vegas. The good news is Renegade Hybrids is in the same town as you. They can fix it if you can't.
Not a deal breaker but a better radiator will cost between $200 and $1000 in parts. It depends on if you do the work or sub it out to a shop.
Some areas of Nevada require emission checks. Make sure you are OK with the conversion. In Cali, that car is exempt from testing but not exempt from having smog equipment. It's very hard for the DMV or CARB to catch this though, since there is no check. You may have to add back on all the SVX smog equipment to pass but check with your DMV.
