Full Version: Mark working on his own stuff? you're kidding right?
Mark Henry
Mark Henry
Mark Henry
Mark Henry
OK, kidding aside....
A borrowed set of DP valve covers...nice to see other peoples mistakes, so you don't make them yourself. biggrin.gif
I have to cut the half cap on the chain cover and then I can make a perfect hole on my turbo cover.
Isn't there also a minor mod you have to do on the turbo covers for the 914?
Mark Henry
I'm almost ready to zip up the case on my type 4
This engine was originally for my 914 but DWS set in (and I took a break for a while, something like 4-5 years ago) and plans changed to a 3.0 /6
Mark Henry
Mark Henry
Woody
Mark Henry
QUOTE(Woody @ Mar 15 2013, 12:14 PM) *
GeorgeRud
If you're using turbo valve covers on a 914-6, you need to machine some of the ribs off the end 1/4 of the lower valve cover to be able to remove the cover when the engine is in the car. Pics have been posted somewhere,but I don't remember where right now.
Mark Henry
yes I found this one and other threads
http://www.914world.com/bbs2/index.php?sho...00517&st=20
MDG
ahem.
Mark Henry
QUOTE(MDG @ Mar 15 2013, 04:07 PM) *
ahem.
I was getting bored waiting for you to bring up your stuff....I can only clean your case so many times then I'll need a cam.
MDG
dry.gif Well it will be here on monday or tuesday . . . I'll let you know and bring it over.
MrHyde
Danm... now i gotta get my 2316 going together... can't have you building 2 engines faster than I bodger together 1... :-p
Have you sent your T-4 in for balancing yet ?? I gotta get mine there but finding a day to goto Toronto hasn't happened yet..
Dr Evil
Mark Henry
QUOTE(MDG @ Mar 15 2013, 04:26 PM) *
Try to shoot for next Saturday, I'm busy all week and on Sunday I have a burn and I'll be totally dead.
QUOTE(MrHyde @ Mar 15 2013, 04:45 PM) *
Try four builds... I'm on a roll....
The T4 is balanced, I need to get the /6 engine done or at least the flywheel assembly.
sixnotfour
Mill the whole covers fins down to the stud bosses....looks better.
Woody
QUOTE(Mark Henry @ Mar 15 2013, 11:18 AM) *
scotty b
QUOTE(sixnotfour @ Mar 15 2013, 06:45 PM) *
Mark Henry
So on the /6 I'm up around 9.9 to 1 CR, I think I can bump that up a bit by off-setting the rod small end bushing.
I need new valves, I'm thinking of going totally custom and using 8mm stems biggrin.gif
Mark Henry
Still didn't get the timing chain housing hole straight, had a brain fart rolleyes.gif
Oh well, not critical any ways. Milled the ribs.
Mark Henry
open....
Mark Henry
Mark Henry
Mark Henry
Mark Henry
