So, I am building slowly a 2056 from a 1.7 and rebuilding a side shifter as spares for the worn out set in the '76. Transmission is done and engine just needs the heads. Machine shop would do the welding of a head crack at the spark plug they but declined to deck the heads on the grounds that they were not set up for something that wasn't a Toyota or Ford. I appreciate their turning me down.
CB engine calculator says that at present deck height (a bit high at 0.055) I won't be able to get the compression I want, which is anywhere a bit north of 8. Also one of the chambers had been through something horrible and was deeply pitted - fixing that meant grinding away 3 cc worth of metal - to 62 cc. That meant grinding the 3 other chambers to match, but made compression worse. So, I decided to see what my little Enco could do.
Yeah, I cringed too, and for good reason. Fortunately there are (were) milled flats around the chambers to reference from, so I took a 10 thou skim off of the valve cover edge to make that parallel and then flipped the heads chamber up and started milling. I spent a half day per chamber on the whole thing with about a half dozen micrometers scattered everywhere. I ended up taking off 0.025 per chamber which brought me down to 59 cc all around (starting from 62). The last thing I did was to mill away the flats around each chamber to provide clearance for the jugs. I decided not to skim the whole head.
So I have a question. I want to use the sealing rings from the gasket kit because they are made to squish just a little. But they are 29 thou thick. That adds quite a bit to the deck height, since they essentially sit on top of the cylinder. In the end I milled a flat groove for the rings 0.025 deep around the edge of the chambers. Is this going to bite me somehow? I know I should have pics, but I don't have them with me.
