I understand that the Lever just closes a ground to the heater motor relay.
Is this the wiring?
If so, I would assume it grounds through the plate and the spade goes to the green/White in the tunnel.
Now The light
If this is the correct wiring, it indicates that the light switches the motor? Does that mean if the lamp blows, the ciruit is broken to the motor? Do I have these wiring diagrams reversed? It also shows a green and ground. Do I jump from the spade on the lever to the light then ground?
Edit: I now see this diagram is the motor itself.
Here is the light. And I do have a Black/Blue
I will try this - and let you all know.
This is a February Build 1973.
