QUOTE(Curbandgutter @ Jul 21 2016, 11:31 PM)
Well the 996 is up on the chassis table. I was surprised to find that it had a twist of 1" in the frame...I wonder how it got that twist?
Frames do some pretty weird things when highly heated, especially if they haven't been previously stress relieved. Moving that far is pretty shocking.
QUOTE(Curbandgutter @ Jul 20 2016, 02:42 PM)
However, what I am trying to do is to get a chassis stiffness so that I know how to set up the springs...As you may already know, a rule of thumb is that if your suspension stiffness is more than 10% of the chassis stiffness, then a portion of the chassis will be flexing and absorbing the loads instead of it going into the springs and dampeners. This condition will give a horrible ride and will cause premature cracks in the chassis. I suspect that this happens quite often when people put a really stiff spring on a stock 914 chassis. As would be my case if I just used the springs off of a car that weighs 3274 lbs and placed them in a car that weighs 2100 lbs.
Glad my comments are helpful in some way.
The 10% rule is good, you figure it keeps your chassis an order of magnitude stiffer so the end effect of its flexing is second order on the overall system. That said, I wouldn't base spring setup off chassis stiffness. What people normally do is decide on a suspension stiffness (say 1 deg/g) and then back out the wheel rate then spring rate, and then make sure their chassis is a stiff enough spring to be ignored.
Ride and handling doesn't have to be poor with a flexy chassis; think about how well some superkarts perform. From what I've read, some of the current F1000 cars also use the chassis stiffness as a tuning knob as well. In a 914 with stiff springs the flexible chassis is definitely bad because of fatigue failures like you noted.
My intent is to help other teener's so that they can see if stiffening the longs truly works. And if so, how well? It will be very interesting to me and to others, I suspect.
I'm very interested to see as well. In a rust-free car I'm not sure there is actually much benefit to long-stiffening with the Engman/Maddog doublers since the area moment of inertia increase is fairly low. On my car I made the longs deeper (well, on the side I'm finished with at least haha) to gain the h^3 advantage in bending stiffness.
I've been reading that a typical torsional stiffness for a sports car is somewhere between 1000 and 2000 ft-lbs/degree. Also, F1 cars can be as high as 20,000 ft-lbs/degree.
I believe these numbers are a little low. We always shot for at least 1500-2000 ft-lbs/deg on our lightly spring formula cars. Just to provide a Porsche comparison, here is some stiffness information I saved from somewhere a few years ago:
Porsche 996 Turbo (early): 9,957 ft-lbs/deg or 13,500 Nm/deg
Porsche 959: 9,515 ft-lbs/deg or 12,900 Nm/deg
Porsche Carrera GT: 19,177 ft-lbs/deg or 26,000Nm/degree
The Lotus Esprit is known for being pretty flexy and is said to be about 4315 ft-lbs/deg.
Current F1 cars I believe are currently much stiffer, though some may also be using their chassis as sprung members; the modeling you can do with $100M+ is pretty crazy.
The numbers above might not be correct since I can't remember the source, but give a little perspective. It should be really interesting to see what your 996 looks like!
