Hey Guys ,
@ValcoOscar @tygaboy @Andyrew @Maltese Falcon @914forme @76-914 thank you for the compliments they really do help with morale.....encouragement helps fuel the project.
Those butt clamps were amazing, and cutting it with the thin 1/32" cut -off while using the fender as the scribe line was the trick. Also doing one half of the fender at one time was very helpful. I used 0.23 welding wire and a 110-volt Lincoln. It worked perfectly! My 200 amp wire welder was too big and it didn't like to push 0.023 wire 15' in the gun. I didn't want to tig cause I'm not good with Tig.
Well I completed the 3 fenders and the last fender is all tacked in. It now needs final welding and grinding. It will take about 30 minutes to complete. Then it's off to the floor and finish the openings in the chassis.
As for the cut-off wheel I didn't know it, but I stumbled onto some super good wheels. I was cutting along no problems and then ran out and got another brand since my local welding store ran out of the ones I was using. So I bought this other set which was expensive and was surprisingly, "made in the USA", but was pure crap. It lasted 12" of cutting into the fender before wasting away. You could watch it reduce in size in real time......ridiculous. And then, dust everywhere. The original ones would last about 12'....feet not inches. So the EXCELLENT cut off was by Pearl and it was a 1/32" thick wheel. It lasts for one fender if you include grinding. However, I think that if I did not grind with it that it could cut all four fenders.....it's that good.
Here is the Excellent wheel that I used.
Click to view attachment Here is the crap one.
Click to view attachment Left Front Fender
Click to view attachmentLeft Rear Fender
