dawg
Mar 26 2013, 08:54 AM
I know there is a left and right torsion bar.
BUT, when you install them does it matter which END goes in first?
In otherwords - there is a left and right bar.
Is there a front and back also?
JoeSharp
Mar 26 2013, 10:02 AM
I went thru this and didn't find an answer. I just tried to put the warn spots back where they were.
dawg
Mar 26 2013, 10:12 AM
QUOTE(Joe Sharp @ Mar 26 2013, 08:02 AM)
Someone has to know. It seems to me that there would be a front and back also, but I'm not positive.
brant
Mar 26 2013, 10:13 AM
I came to the conclusion, that you want the marking for LR to be on the front of the car, or where they would be somewhat visible after installation.
mskala
Mar 26 2013, 11:30 AM
Torsion bars are like tube socks; initially they are neither left nor right but after being used, it has been assumed that they take a set, meaning that you are best
to put back in the same side and orientation. The bars have L and R printed on
them to help the user in this regard but they have no special differences when
made.
JoeSharp
Mar 26 2013, 12:15 PM
QUOTE(mskala @ Mar 26 2013, 10:30 AM)
made.
That is why I looked for the ware and put them back where there were.
Dave_Darling
Mar 26 2013, 06:34 PM
Actually, they can be swapped end for end--the rotational stress is in the same direction. And, at least according to the late Bruce A., is the reason you keep the L ones on the L and the R ones on the R. Reversing the rotational stress on them shortens their lifespan.
Take a pencil and put an arrow pointing to the side one way on one end, and one pointing to the side the other way on the other end. Then turn the pencil end-for-end. Note which way the arrows point: It's the same direction as you started with.
But if you want to put them in the same direction and the same side, that works fine.
--DD
Socalandy
Mar 27 2013, 09:36 AM
When mine came out the L/R markings were up front and the rotation arrow in back with the curved arrow pointing outboard.
dawg
Mar 29 2013, 02:04 PM
QUOTE(Dave_Darling @ Mar 26 2013, 04:34 PM)
--DD
perfect - totally get it!
