I have a 85 911 oil pressure and temp gauge. Got senders for them and they both did not work properly.
Temp gauge climbed quicly and pegged in less then a minute. The oil pressure jumped from its resting place when ignition vwas turned on but did not move when the engine started. Oil pressure dummy light turned off when the engine started. Oil pressure gauge is a 5 bar gauge. Thinking it is the senders. How do I find the correct senders? Gauge is stamped 6/85'
Thanks Irv
