neo914-6
Nov 20 2004, 01:46 AM
On Chris Julians car, purchased ~10 years ago.
Felix
redshift
Nov 20 2004, 02:01 AM
I am half asleep, but they look like several made now... those might be RSR spec Bils...
I dunno... Santa? Santa Claus?
See, I am asleep..
M
davep
Nov 20 2004, 10:19 AM
They sure look like Bilsteins. I had a similar set except they were 911 rear shocks. Probably available, but expensive.
TimT
Nov 20 2004, 01:17 PM
Those are Bilstein RSR struts
neo914-6
Nov 20 2004, 04:55 PM
Tim,
Then whats the extra spring? Is this strut overkill for non-race cars?
Found a source:
Bilstein RSR $1200 pair.
Felix
redshift
Nov 20 2004, 04:57 PM
Overkill for non-race cars... hmm.. no.
M
TimT
Nov 20 2004, 05:03 PM
That extra spring is a "helper spring" so when the strut is unloaded, the springs still stay centered and in contact with the perches. The helper spring has a really low rate... less the 25 lbs...
Its not really necessary, but sometime when you let a coil over car down off the jack a spring can hang up, it upsets the ride height for awhile till you hit a good bump... but it can screw up the perches.
Youi can also get a short progressive spring, and then a final value linear spring to run..Eibach can be very helpful.
redshift
Nov 20 2004, 05:35 PM
The prices are soaring... last year you could get the whole rig for about as much as the inserts.
Anyone want these dollars? Bushel for a dime..
M
TimT
Nov 20 2004, 05:41 PM
Found a source: Bilstein RSR $1200 pair.
thats a little steep
but you have them already? dont you?
neo914-6
Nov 20 2004, 09:05 PM
Are there cheaper, where? I have 911S with adj. Konis on my car. The pictured struts are on Chris Julians V8 AIR bodied caged car. He bought them ~10 years ago and forgot where. I am researching parts to put on my next 914.
Felix
redshift
Nov 20 2004, 11:00 PM
Rich Herzog (ArtechnikA) was either buying, or looking for them during the Bils buy..
Brad had a price... PM Rich?
M
ChrisReale
Nov 21 2004, 02:56 AM
QUOTE(TimT @ Nov 20 2004, 03:03 PM)
Happened to me the other day. I thought some kids were throwing rocks at my car...it was the spring "settling" on the perch after being jacked up..
neo914-6
Nov 21 2004, 03:08 AM
My rears are Bilsteins with the adj. perches and shorter 200lb springs. I've been told you can tie wrap the top of the springs to keep them in the mount but then the bottom may miss-align.
Felix
