Next time you are having "a harder time finding the 17mm allen wrench locally than I did 90w"... Then try this trick.
I spent a while calling around trying to buy the 17mm allen tool locally... no luck "we could order one".
While buying Lucas SAE-80W-90 GEAR OIL, the previous customer was buying wheel lug bolts.
The catalog was open and I wondered "do they make metric lug bolts?" well of course they do.
17mm Head Lug Bolt - $3
I ground the sides flat to 11mm just to find I was able to get the plugs loose with a 17mm Open end (a flat one) under the shoulder of the stud.
$3 plug removal tool, and weighs about 1/5 for those that haul them around.
I applied pen oil and they didnt come right out.
Gently warmed up the case around the plugs with a torch for about a minute, and they popped right loose (very clean case).
Now for the trans oil:
Is Lucas SAE 80W-90 GEAR OIL - Trans & Diff Lube any good?
The label says "Exceeds service level API GL-4, API GL-5, API MT-1, SAE J2360 (MIL-PRF-2105E), MACK GO-J, PG-2 LIMITED SLIP" for anyone who knows what that means.
Stu
