QUOTE(pcar916 @ Apr 1 2013, 05:14 PM)
The 930 CV's are 108's, but the 911's are 100mm, as are the 944's. The 930 and 911 splines are indeed the same though. The 914 spline-count is the same as the 944.
911 axles (including 930) are not long enough to use in 914's if you're using the 914, 915 or 930 transaxles without a spacer. I don't know about the flange spacing on a Suby transaxle.
I just measured both a 914 and 915 and the distance from left to right flanges is ~240 cm, or about 9.5 inches. I'm not near my 108mm CV/axles to measure the thickness of the spacers but somebody out there is using them and can transmit the measurement. To the hub...
I think you're talking about the stub axles and those bearings. I'm using 911 SC (1979) stub axles and hubs (hats) and have used both 914-6 stub axles as well and they have both fit perfectly. Right now I'm using 100mm 944 CV's and modified 914 axles because the splines fit. I used the 930 axles/CV's with spacers for a couple of years as well with no problems. They're WAY heavy though. Like pounds heavier per axle.
Good luck
I hope someone out there can help my car has a 911 sc 3.0 and it sounds awsome if I feed a little gas through a spray bottle
WUR (warm up reg is fine)
Cold start valve is fine
It is wired right and I am at a lose as to why it wont idle on its own.
Pleas if anyone can help or point me to someone who can help
I have stuck with the stocke 911 injector system
