Started hearing a noise coming from the front left wheel going over bumps, like something had come loose in the suspension. No change in handling or stearing noticed just a noise. I jacked the front left up at the frame jacking ring so the wheel hung off the ground. I can easily lift the wheel up about an inch so think this is what is making the sound.
Looking at the shock and strut assembly I can see what looks like the threaded part in the picture, up in the very bottom of the Top Strut tube. Isn't this supposed to be screwed into something? Maybe the lower tube or shock. If so, I'll try to slide it down the rod and hopefully screw it in. Pretty sure that will be the fix if it's not damaged.
(This picture was from someone elses Thread but looks like the same Strut that I have)
