The bolts that hold the right side aluminum fender on my trailer pulled through the bolt holes. I tried to re-attach it multiple times with no success. I figured, no problem...I have a mig welder & will re-weld the fender. Picked up some aluminum welding wire from Home Depot and went to work. Working with a Hobart Handler 140. I was able to get enough weld on to do the job, but the gun kept jamming. The wire would bind where it feeds into the line to the gun where it "pushes" the wire. It took about 10 jams/clearing of jams to get the job done. Any suggestions for aluminum welding with this setup?
