QUOTE(Dave_Darling @ Apr 1 2013, 02:15 PM)
If you are confident you can set the trailing arm exactly where it was, with absolute precision, you don't need an alignment.
I would disagree. If you have replaced the bushings, there is a good chance the slack you have taken up with new bushings is now enough to cause the previous settings to be inaccurate. Whenever any components are replaced on a suspension, the car should be re-aligned. If nothing else, as mentioned previously, you are risking tearing up a set of tires.
Full disclosure though, I just replaced my bushings and I have not re-aligned the car. But it's on an old set of tires and we will align it before the new track-intended tires are installed.
