So, I decided to check my suspension bushings and see what size torsion bars were in there. The rubber bushings were not in that bad of shape, but while I have it apart I ordered polybronze bushings to put back. The good news was that I discovered that someone had previously installed 22mm torsion bars. I wanted to put in at least 21mm bars, so I'll just keep what I have. The bad news is that the one marked R was on the left side of the car, looking forward, and the one marked L was on the right. The book says not to switch these, so should I put back the L on left and the R on the right now and does it matter which end goes to the front, that is the marked end or the unmarked end?
Thanks in advance.
