QUOTE(tornik550 @ Apr 2 2013, 02:00 PM)
Are these nuts acceptable to use as exhaust nuts. They are normally used for intakes. They are made of brass. They have a thinner wall than normal for extra clearance. I know the copper nuts are the standard however would these work?
I have used them without issue but you will want to get a sturdy washer under them depending on which heat exchanger you are using. They are narrow enoungh and soft enough to work into the exchanger without a strong enough washer. Few things a like about them, not the least of which is that I can get them at my local AC VW shop. Dont have to deal with the socket getting pinched, and I actually like the fact that they are a softer metal as well because you are more likely to damage the nut if you overtighten them rather then the stud or the head. Pick up an extra set and double nut them for insurance.
I have seen one place online that made this same size in steel but dont remember where that was.
Whatever you do just dont use those coper plated lock nuts unless you fell like punishing yourself down the road!
