Trekkor
Nov 20 2004, 06:22 PM
There is a #05 stamped on the end.
Likely in a 2.2 motor.
help!
KT
Cap'n Krusty
Nov 20 2004, 06:35 PM
Gimme the numbers embossed on the shafts. One side or the other will do. I dunno about any numbers on the end. The Cap'n
J P Stein
Nov 20 2004, 08:38 PM
....or measure the lift on any valve & report back. I can give a SWAG with that.
sixnotfour
Nov 20 2004, 10:36 PM
E or solex Unless someone has reground them. check overlap measurement to know for sure.
Trekkor
Nov 21 2004, 10:39 AM
What should I expect of them? HP and performance?
KT
Trekkor
Nov 21 2004, 02:11 PM
This may help? 901/06 8372
sixnotfour
Nov 21 2004, 02:26 PM
901/06 130HP/6100rpm 9.0/1comp. 2.0 liter If its stock. 1966/67 motor E type cams great all around.
J P Stein
Nov 21 2004, 02:31 PM
901/06 is the 67/68, 911L......2.0L, 130hp @ 6100.....128ft/lbs
torque.
God knows what's been done to it in the last 30 odd years.
oops, I'm slow
sixnotfour
Nov 21 2004, 02:36 PM
68 uses different numbers 901/14 901/17 from july 67 901/07 same motor specs .
If its stock
McMark
Nov 21 2004, 02:40 PM
I have a gauge to measure lift. When should I bring it by?
sixnotfour
Nov 21 2004, 02:47 PM
that would be a great Quickie to end some of the mystery motor topic the numbers really dont mean much these days as JP stated.
Trekkor
Nov 21 2004, 06:13 PM
This is fun. It's almost like a guessing game!
911 specsengine
1964 901 / 911
1991 cc
130 bhp @ 6200 rpm
162 NM @ 4600 rpm
compression: 9,0:1
1965-1967 911
1991 cc
130 bhp @ 6100 rpm
174 NM @ 4200 rpm
compression: 9,0:1
1967-1968 911 S
1991 cc
160 bhp @ 6600 rpm
179 NM @ 5200 rpm
compression: 9,8:1
1968 911, 911 L
1991 cc
130 bhp @ 6100 rpm
176 NM @ 4200 rpm
compression: 9,0:1
1968-1969 911 T
1991 cc
110 bhp @ 5800 rpm
156 NM @ 4200 rpm
compression: 8,6:1
1968 911 S
1991 cc
160 bhp @ 6600 rpm
180 NM @ 5200 rpm
compression: 9,8:1
1969 911 E
1991 cc
140 bhp @ 6500 rpm
175 NM @ 4500 rpm
compression: 9,1:1
1969 911 S
1991 cc
170 bhp @ 6800 rpm
183 NM @ 5500 rpm
compression: 9,9:1
1970-1971 911 T
2195 cc
125 bhp @ 5800 rpm
177 NM @ 4200 rpm
compression: 8,6:1
1970-1971 911 E
2195 cc
155 bhp @ 6200 rpm
191 NM @ 4500 rpm
compression: 9,1:1
1970-1971 911 S
2195 cc
180 bhp @ 6500 rpm
199 NM @ 5200 rpm
compression: 9,8:1
I mentioned it has a mechanical advance dizzy, right. With rev limiting rotor. Somebody said 2.2's had that?
KT
Trekkor
Nov 21 2004, 06:16 PM
Non- magnetic cylinders, too. Nickies?
KT
sixnotfour
Nov 21 2004, 08:09 PM
Biral alum. fins cast iron liner , Got the lift yet ? could be a hot rod or just a 67 911 2.0 Lets take it apart
nebreitling
Nov 21 2004, 08:14 PM
are you taking this thing apart, trekkor?
p.s. for your sake, i hope it's a hot motor. for my sake, i hope it's not (looks like we'll both be in Fm!)
Trekkor
Nov 21 2004, 09:13 PM
Guess what?
Not taking it apart!
Right now it runs good and I'll enjoy what I have.
KT
