The tank on my 75 had some loose rust particles accumulated around the screen, and any sudden turn would cause the car to stall. Very bad in a 914, right? I examined some extra tanks I have, and found one from a 73 that was in excellent condition inside. The 73 and 74 appear to be identical in every respect. The 75 does not have the mounts for the charcoal canister, the mounts for the expansion tank are different, and the strainer screen is about a third the size of the pre 75. Expansion tank on the 75 is plastic. Looks like the tanks themselves are identcal. I changed tanks, and filter, and all is well now. I can slide all the way around a corner (roads are wet today
)and no more stall
pre 75 expansion tank, charcoal canister, and filler weigh 6lbs 8oz. The 75 weighs 2lbs 14 oz
BTW, I started with one gallon of gas in a dry tank, drove two blocks to the gas station and the reserve light went off at 2.3 gals.
