I see in the haynes manual, that it states "do not forget the washer between the cooler and the crankcase" during the cooler installation instructions.
However the PET catalog does not show any such washer or even the nuts that hold down the cooler.
After digging throug the PO's box of nuts and bolts (I wasnt the one to take this particular engine apart), I found three aluminum flat washers 2.5 mm thick that are the same ID as the cooler studs.
Would these be the washers that the haynes manual hints at?
I would assume if they DO go in there, it is to keep from over crushing the seals.
The cooler and the case both have a recess for the seals, so it is not obvious if these are required.
Another question: I bought Jake's engine sealant kit, so is anything from that kit recommended for the oil cooler seals? (Dirko, Curil, Loctite, etc)
I know the mantra: "Just use engine oil" but after buying the kit I figured I would ask.
I used a very small amount of the Dirko on the strainer gaskets since aircooled.net suggested that was what it was good for.
Stu
