I have most of the parts needed for the 5 lug conversion I'm immersed in. Most of the parts for the front end (we think) came from a 911 SC. (Koni Struts, Koni inserts) Not sure about the hubs though. Not sure if they came from the same donor 911 or not, but fairly sure they did.
The hub and struts came apart - the struts were blasted and powder coated, so hubs, calipers came in different boxes.
Look at this picture (from AA)... Copied from
http://www.autoatlanta.com/porsche-parts/9...8-83/402-00.php
I see three different part numbers for hubs (item 25). Hence my confusion. I can't find any part numbers on the hubs at all. Except in the bolt holes these set of numbers (911.341) (605.4R) and N1926
I'm curious about parts 23, 24, and 25A - as these all seem to be missing from the parts I have on hand and I'm curious if they are needed or were not part of the setup I'm using??
I'll post some pictures of what I DO have later today. For now I just wanted to kick this off to see if I could get a bit of an education on 911 setups.
