Full Version: Relay amps
partwerks
The dude at Pelican can't seem to tell me what the amperage is for this relay.
Is there any way to tell?
The relay you are looking for is part number 141 951 253 B and is forsale for $6.75
I was thinking of putting one in with more amperage in place of the stock one since the addition of the H4's 100W, I believe.
Mike Bellis
100W @ 12v =8.3 Amps. Most relays are rated for 20 Amps minimum. You should be OK. Use 2 if you are worried.
Dave_Darling
A Google image search showed this:
http://www.amazon.com/RELAY-MULTIPURPOSE-1...T/dp/B00B2WQ6N0
It says 40A on it.
200W / 14V = 14A, which is well under 40. So it's fine.
--DD
76-914
our electrical group is top notch. thumb3d.gif we have some walking dictionary's here.
partwerks
If it makes any more difference, I am using those pilot lights as well.
Where do I stick the second relay?
partwerks
Isn't the relay for the lights a round or, or is it rectangular?
Cap'n Krusty
Different. The relays at the lights are for the motors. The lights themselves don't have relays. This relay will be for the lights, which put too much load on the switch. Common VW problem.
The Cap'n
partwerks
So I never really had a relay for it under the dash??
