Full Version: Headlight/power issue?
corsepervita
So the 911 has been down for about a week now. I've been taking the opportunity to drive the 914 now that the timing is set right and she's running proper. Feels great!
Except that this morning my headlights were flickering every now and again.
The odd thing is that the dash didn't flicker, the radio has no issues... At first I wanted to say "Generator issue?" and it very well may be, but classically when I've seen generator issues all the instruments and the lights dim. Not the case here. I'll probably check it tonight when I get home.
Any ideas on a quick way to test it?
Hope everyone is getting some warm weather and getting their 914 out for a spin!
7TPorsh
sounds like a loose connection. Both headlights? check between the switch and the driver side light. Also grounds.
Cap'n Krusty
Spin the fuses in their contacts in the fuse box. Better yet, remove them, clean the fuse box and replace the fuses.
The Cap'n
