Last summer, I purchased a new ate 19mm master cylinder. For some reason, my cylinder did not have the rubber grommets for the reservoir lines. I purchased new grommets and installed them. I was constantly having a slow leak from the top of the MC- not from the lines.
Earlier tonight, I removed the MC. I assumed that I probably didn't install the reservoir lines into the grommets. I removed them and found that I had not installed the washer under the grommets.
Tonight I installed the washers and new grommets. I unhooked the fluid reservoir so I could get some slack on the lines. Because of the slack, I was able to push the lines into the grommets easily. I pushed them as far as I could.
My questions-
1. Could leaving out the washer under the grommets cause a leak?
2. Does it matter which reservoir line goes in the master cylinder holes?
3. How do I know if the reservoir line is properly seated?
4. Anywhere else on top of the MC that could cause a leak?
