QUOTE(Scott S @ Apr 17 2013, 04:03 PM)
Hi Rich -
I have only owned the car since January. It has been driven very little in the past 2-3 years (like 600 miles). The ball joints and tie rods were done in 2010.
I drove the car a bit when it first was delivered, and as I recall everything seemed fine - but I was listening to every noise/bump/etc as the car was new to me and I was trying to figure everything out. Because of this, I cannot say with any certanty that the car has had this steering issue from day one or not.
A month or so ago I threw the nose of the car up on jack stands to simply do some cleaning and detailing - and to drill off some wheel locks (the key was not included with the car!). While up in the air, I noticed that the passenger side swaybar arm had partially slid off of the actual bar (it was very close to the strut housing). I loosend it up, slid it back on the bar with absolutely no drama, and tightened it up. The car was on jack stands for probably two weeks while I continued cleaning.
When I put the car back on the ground and went for a drive, I had a clunk in the front end - but I do not remember the steering being as bad as it is now. I poked around under the car and found only one source of noise - the front sway bar makes a clunk moving horizontally throught the body. The arm I had re-attached still looked as it did after I fixed it. I figured the sway bar bushings were bad and ordered a new set (along with new drop links) from Weltmeister, but have yet to install them.
If the sway bar bushings are perished, it's likely most of the other bushings are too...and here's where the slippery slope begins. If you search you can find a thread where I had a squeaky sway bar bushing (diagnosed by Rory). That led to a full suspension rebuild, front and rear!! Not to say you need this, I do know that after I swapped the sway bar bushings and before I rebuilt the rest of the suspension, my car felt very very different in a good way.
Also, the clunk and the dead spot may be unrelated. Clunks and squeaks are cured by replacing bushings in my experience.
Here is the crazy part. On my next drive (when I noticed the steering was really stiff/not coming back to center), I also realised that the clunk in the front end had become far less noticable. It is absolutely still there - but way more quiet.
I do know for a fact that when the nose of the car was up on jack stands (with the front wheels off) the steering was very smooth. I went to full lock in both directions many many times while scrubbing the wheel wells.
IMO -- and I am no professionnal, maybe Rory will chime in again -- but this definitely points to alignment. Of course, it could be some other component that is only cranky when it's under load, but if the action is smooth in the air then the rack, tie rods, spindles, steering linkage, etc. are probably ok.
crazy.
One last thing to check -- the bushing in the steering column disintegrates over time and this could also be the cause of your issue. Does your steering wheel have up/down/left/right play? Pull your steering wheel off and check it out. Mine had turned to dust, and it was a low mileage princess when I got it (62k).
Mitch Leland sells a replacement made of delrin that works a treat -- you can get it direct or at PP. I would avoid the metal 928 hammer-in part, as it really isn't made for the 911 and didn't work for me nearly as well.
in conclusion
