QUOTE(mepstein @ Apr 16 2013, 01:13 PM)
High beams haven't worked for a while. Now neither setting works.
It is possible (though not probable) that the high/low relay is stuck in between. There is a plastic cam inside the relay that toggles back and forth.
You should turn on the key, turn on the headlights and test for power at the high/low relay. If you have power on the red wire and not on the white or yellow, the relay is bad. It may be bad already since the highbeams don't work.
You should also verify you have a constant power at the bucket relays up front. Those relays have power all the time from fuse #12.
I think you have multiple problems.
