vintage914racer
Nov 22 2004, 06:57 PM
I have a compufire distributorless ignition system for a four cylinder vw/porsche that is sitting around not doing me any good, since I have sixes. Any idea what it is worth? Anyone interested?
SLITS
Nov 22 2004, 07:18 PM
If it's a DIS - IX, it still uses a distributor (009) to trigger the coil(s). I thought they listed for about $250. I bought mine for $130 off EVILbay.
914werke
Nov 22 2004, 07:22 PM
SLITS
Nov 22 2004, 07:54 PM
Really?
Mueller
Nov 22 2004, 08:04 PM
Hey Slits....
is that system wasted spark?
programmable?
Aaron Cox
Nov 22 2004, 09:18 PM
so you cant adjust advance etc.....
Mueller
Nov 22 2004, 09:27 PM
QUOTE(Aaron Cox @ Nov 22 2004, 08:18 PM)
according to the directions, the advance is mechanical..inside the housing
Installation instructions
lapuwali
Nov 22 2004, 09:37 PM
It's just a crappy 009 dizzy with two twin-post coils. Same bad advance curve, same fix to bad advance curve (find someone that still does that). I suppose there would be some minor benefit over a straight Pertonix-type electronic ignition, but I'd doubt if it could even be measured over a properly curved distributor.
A MUCH better idea is a doodad a place called 123ignition is working on (for VW/Porsche applications soon). A complete, self-contained distributor with all electronic advance control. The only moving part in the thing is the rotor shaft (in a sealed bearing, not just a sloppy bushing). Several curves to choose from (set of 16, selectable using a rotary switch). Not user programmable, but the supplied curves should be adequate. Vacuum advance/retard is also available. The only trick now is it's not yet available for VW (they're in the Netherlands, and only supply parts for Citroens now), and it will likely be fairly expensive in the US when it does get here (I'm guessing $300 or thereabouts).
vintage914racer
Nov 23 2004, 12:50 PM
I have what is shown in the picture slits posted. I never said it was the greatest system, just that its sitting around in my collection of parts and not in use.
SLITS
Nov 23 2004, 01:48 PM
Ahhhh, the experts on the board. You can take the guts outta the "crappy" 009 and put them in any Bosch 4 cyl dizzy. You can even put it in ones with the trigger points.
But...............I didn't buy it for what it is............I bought it for the sexz appeal.....when I show up at the WCC05
Oh, and I will let you hold onto the end of the high tension wire while I crank it over
I gotta change my avatar - I looked in the mirror and I'm beginning to look like Howard
J P Stein
Nov 23 2004, 02:20 PM
QUOTE(SLITS @ Nov 23 2004, 11:48 AM)
EVERYBODY will think it's fast............just because. I'm gonna leave the engine lid off so that that blue anodized billet cap reflects the bright California sun.
I like your style, sonny.
TGM
Nov 23 2004, 09:59 PM
I've got the same setup but with 050 distributor. Jake convinced me to switch to Mallory so mine is available for sale too.
scooter311
Nov 24 2004, 07:51 AM
I'm with SLITS on this one - Bling Bling! I wanna buy one, I need to be hip.
