QUOTE(914itis @ Apr 16 2013, 06:46 PM)
I replaced my front suspension with a 912e, I was told that it is the same as a 911. Last week I decided to put back the steering pan and I got a big surprise. It is completely different.
To answer your questions if the 911 is the same as a 912, then it will not fit.
You failed to ask the right question! 911 and 914 steering rack covers ARE the same, "IF" you consider "WHICH" 911/912 you're gonna get the parts from. When they moved the sway bar they had to change the configuration of the cover. The 912E cover "IS" the same as the one on a 911 of the same year, but NOT the 914, and a 912E is NOT the same as a 912. That's why they call it a "912E" and not a "912".
The Cap'n
