[quote name='r3dplanet' date='Apr 18 2013, 12:13 AM' post='1851662']
It's not an Allen bolt, it's an 8mm "triple square" twelve point socket. That is, unless someone along the way replaced the correct bolts with standard Allen bolts. That would not be fun to extract if they stripped. Hence, twelve points.
You can buy one from Pelican here:
http://www.pelicanparts.com/More_Info/PEL-...2%20in.%20driveBut you also get them from NAPA or a local Beetle shop.
quote name='John1180' date='Apr 17 2013, 10:49 PM' post='1851659']
Need to pull CV half shafts, what size cap head Allen do I need?
[/quote]
[/quote]
You're only partly correct. Early cars had 6mm Allen head bolts, later cars used the 8mm triple square design. Less chance of stripping, able to take a little more torque without chingering up both the bolt and the tool. Personally, I prefer the triple square variety, but the Allen head bolts are fine. Both require cleaning the head before attempting to remove the bolt. One advantage of the Allen head is you can hammer a triple square tool into a stripped bolt to remove it. Can't do that with the triple square bolt.
The Cap'n
