Full Version: Problem indicators switch?
porschefile2010
Hi. Not sure if anyone has come across this before.
Finally got the engine back into my full repaint 75. Hooked everything up. Indicators left work just fine. Indicators right veryfaint and the elctrical gauges and rev counter crash out ?? I had the steering wheel off at one stage. Could there be an earth problem in there causing something like this?
Thanks again.
914Sixer
One of the turn signals is not hooked up right. Wiring is switched. Going to ground
porschefile2010
Thanks Mark. So I take it you mean the problem is with the terminals at the actual light box?
Richard
