QUOTE(JamesM @ Apr 20 2013, 04:56 PM)
I will need to go look to confirm, but i believe no, i think you have the plastic spacer flipped. Also i think your AAR need to be flipped 180deg as well.
Air inlet on spacer should be on bottom, hose from AAR then is to the lower of the 2 ports to the CSV spacer.
Like i sad, not 100% on this as i need to go look
There are four possible positions - took a WAG at it.
Nipple on the plastic spacer, faces to the right pointing up, right pointing down, or left pointing down?
Current position in pictuer is left pointing up.
