I am going to purchase an accusump for a 2.0L 4 cyl vintage racing engine.
I have an oil cooler (maybe an extra quart) so ~5.5-6 quarts total.
I was going to get the 3 quart, but that got me thinking "What if I forget to close the valve when I shut off the motor?"
Overfilling the engine by 3 quarts and then trying to start it after sitting for a while might not be a good idea.
That is even IF it does not overflow from somewhere.
What is everyone else running? I see they come in 1,2, or 3 quarts.
Also, the oil cooler will be mounted under the rear trunk right behind the oil filter.
The accusump will sit right above that in the rear trunk.
Thoughts on that setup?
Stu
