Harpo
Apr 23 2013, 05:42 PM
I took my fan apart to get it powder coated and now I'm wondering if I screwed up. Does it matter how it goes back together? If it does I have a 25% change of getting it right. Sure does look nice though
Click to view attachmentThanks
David
rhcb914
Apr 23 2013, 05:45 PM
you have a 25% chance of getting it right. Although with the fresh powder coating even if you hit the jack pot I would still re-balance it
ThePaintedMan
Apr 23 2013, 06:12 PM
It is pretty. No one will ever see it, but it's pretty
reharvey
Apr 23 2013, 06:26 PM
The best impeller fan is one that has never been disassembled. Don't be surprised if the pulley wobbles when it spins. Nobody will ever see it so get a dirty used one that has never been apart.
Mblizzard
Apr 23 2013, 07:29 PM
While not many people will see it, that is something that was done well! Nice, very nice!
StratPlayer
Apr 23 2013, 08:49 PM
I powdercoated the impeller a while back. I used chrome powder, I did have the impeller balanced after it was powdercoated.. I marked the impeller before I disassembled it so it would be put back the same way.
bigkensteele
Apr 23 2013, 08:57 PM
Can a typical machine shop balance our fans?
StratPlayer
Apr 23 2013, 08:59 PM
The guy that balanced everything the impleller was included.. wasn't a machine shop that I used.
JStroud
Apr 23 2013, 11:19 PM
That turned out awesome!
When I rebuilt my motor I had my machinist balance everything, if it moved or rotated it got balanced, including the fan....makes for a smooooth running motor.
Jeff
bdstone914
Apr 24 2013, 10:09 PM
I really have to wonder how much fan balance matters.
I have pulled several that must have had 1/2 pound of dirt stuck to the fins.
That can't be balanced with that much dirt.
Bruce
kwlane
Apr 24 2013, 10:18 PM
Smoother surface = more air = more cooling? Well, Maybe not that much difference in cooling but a good thought even if never see it!
Jake Raby
Apr 26 2013, 06:51 PM
We avoid fan disassembly at all costs. Its near impossible to center the fan ring perfectly without a jig made for the purpose.
On the balancer it can take us an hour to dial one in after it has been disassembled.
