mramber
Apr 24 2013, 06:10 PM
Hello 914 world,
I have loved these cars since the early 70's when I was a kid and I always knew one day I would own one. Two weeks ago I bought a 73 1.7, I have to wait another week and a half to get it home but I am curious about the transmission. The car has a 4 speed transmission and everything I read about the 914 says they only came with a 5 speed. Would this have been a swap from a 911? Or, were there some 914's with 4 speeds?
I would like to add engine, VIN, and transmission numbers to help with this question but I won't have the car until May 4th.
Thanks all! I'm excited to finally own the car of my dreams!
Mike Bellis
Apr 24 2013, 06:41 PM
Most likely you have a 5 speed in need of a linkage adjustment.
mramber
Apr 24 2013, 06:54 PM
I thought about that but this thing has reverse on the left up, then 1 next to reverse over and up, 2 down, 3 right and up, 4 down. When I drove it, I couldn't have been starting in 2nd gear could I?
Mike Bellis
Apr 24 2013, 07:13 PM
QUOTE(mramber @ Apr 24 2013, 05:54 PM)
1st gear is left and down, under reverse. You might be starting in second gear.
ThePaintedMan
Apr 24 2013, 07:53 PM
A common mistake, especially if the shift knob didn't have markings. As Mike said previously its over to the left and down
Can't wait to see pics!
Apr 24 2013, 08:03 PM
QUOTE(mramber @ Apr 24 2013, 08:54 PM)
Yes
1st is left and down. It's in there unless your trans is really broken.
Dr Evil
Apr 24 2013, 09:01 PM
mramber
Apr 25 2013, 04:03 PM
Thanks all, once I have the car I will check the linkage and trans out. I knew that 1rst was left and down, but the current owner says it is a 4 speed so he must be starting in 2nd. As a result I did the same when I drove it, I didn't even try to go left and down. Can't wait to get the car so I can solve this mystery (and go for a nice drive!)
Dr Evil
Apr 25 2013, 06:24 PM
While it is definitely possible to convert the gear box to 4 speed, it would take money, effort, and necessity. It would largely be a step backwards so, like the others, I doubt it. Cant wait to hear what you find.
mramber
Apr 27 2013, 08:03 PM
Mystery solved, the car is home and I found first gear to the left and down just where it had been hiding. The prior owner had been starting in 2nd for the past 15 years.
This car is a blast to drive!
abnrdo
Apr 27 2013, 08:13 PM
Nice! May I ask where you purchased that car from? I think I have seen it before.
Dr Evil
Apr 27 2013, 08:39 PM
Starting in 2nd for 15yrs??? That either means your 1st is probably in great shape (SCORE!) or it failed and they stopped using it. I hope it is the former.
mramber
Apr 28 2013, 04:22 PM
QUOTE(abnrdo @ Apr 27 2013, 09:13 PM)
I'm in Minneapolis, I bought it from a guy that had it stored up by Fargo.
I need to put some sunscreen in the car. All day driving around and now my face is sunburned!
billh1963
Apr 28 2013, 08:11 PM
Nice looking car! Congratulations!
I use U-Haul trailers all the time to haul 914's. Why is the car not at the front of he trailer...which allows you to use the ratcheting straps? Just curious....
Drums66
Apr 28 2013, 09:49 PM
.....If all ihe things said are true; you might need a clutch
soon?
....WELCOME...
