Folks,
I have a 74 914 with a single carb and I'm looking to replace the fuel line from the tank, thu the tunnel and to the carb. I'm having some welding done at a local shop, so the engine is out and the frame is up on the lift... perfect time to replace fuel lines right? The fuel line in the engine bay is "smoky" clear, so I'm assuming its the original fuel line.
I've seen recommendations for SS fuel line vendors, but none for rubber/plastic line replacement..... any recommendations?
