TomR
Apr 26 2013, 07:58 PM
I've got a '73 914-4. It has a 2.4L 4 cylinder. 150-160hp & 170 ft lbs of torque. I'm running Yokohama Advan Neova 205x15 tires. At track events oil pressure drops precipitously on sharp turns. I have an accusump which helps a lot, but was wondering if there are any deep sump baffled oil pans to prevent oil starvation. Any help would be great
Thx, Tom
McMark
Apr 26 2013, 08:15 PM
Most autocrossers end up with the 'tuna can' sump extension, and usually run 1/2q over the full line to battle oil starvation.
Beware that the steel deep sump has been known to have sub-par welding and can have pinholes that leak right out of the box. I've heard of it and I've had one that did it that I rewelded all the way around.
messix
Apr 26 2013, 08:18 PM
there is no real "oilpan" on the t4.
there is a thing called "the tuna can" that does drop the oil pick up and screen sump a few inches but you don't get much in added oil capacity and it lowers you ground clearance under the engine.
McMark
Apr 26 2013, 08:41 PM
Troy, the tuna can isn't lower than the engine bar though.
Jerry75914
Apr 26 2013, 09:04 PM
I believe it was my tuna can that Mark is referencing. It has been perfecto after Mark re-welded it, and best of all, no more green light of impending engine death! I used to hit it contantly after I got my 2270, thankfully, I only see it at start up now. I highly recomment putting one in!
ThePaintedMan
Apr 26 2013, 09:45 PM
Or contact Jonesy here. He is in the U.K. and makes a stellar unit, similar to the Tuna Can but better. Can't help but wonder if this was one of the rare
things that VW/Porsche didn't think of. You build a sportscar that relies on oil pressure and handles like a go-kart, why didn't you think about keeping a "reserve" of oil for those crazy corners?
Mark Henry
Apr 27 2013, 07:02 AM
QUOTE(ThePaintedMan @ Apr 26 2013, 11:45 PM)
They did.... it's called a /6
ThePaintedMan
Apr 27 2013, 07:28 AM
QUOTE(Mark Henry @ Apr 27 2013, 09:02 AM)
Touche Mark, Touche.
SLITS
Apr 27 2013, 08:36 AM
On the race cars (not Porsche) we had deep sumps, baffles, windage trays, crank scrapers ..... still saw 0 in the corners and lost engines.
The thing that saved the motors was the accumulator we had installed. It held about 2 quarts. It wasn't a name brand ... it was a 3000 psig rated hydraulic accumulator out of a 707.
Other solution is a dry sump system .....
yeahmag
Apr 27 2013, 09:42 AM
My car is a testament to that. I think if you are in street tires a tuna can is fine.
