QUOTE(Hine62 @ Apr 28 2013, 07:23 AM)
Should I assume that the rear wheel bearing needs to be replaced if the wheel wobbles without the axle installed?
hine62
I had an experience with an aftermarket brand bearing. It is brand new, pressed into the trailing arm fine. When I started to press in the hub, halfway in, as the hub was through the outer race, the hub could wobble. I wasn't sure if that broke the integrity of the bearing, but I pressed it through and running with it now.
I've only put on couple hundred miles. Never had that experience with other bearings.
I tightened up the axles and waiting to see how it works out.
